2001 Cadillac Seville STS, ABS/Inputs/Outputs Waveform
this is voltage on the pin for steering wheel position sensor (SWPS). this capture is with all pins connected to SWPS, but when i remove this one single pin i have same waveform. this same wire is spliced to 2 other sensors (yaw rate, lateral accel) and then s...
| Engine | 4.6 L / 8 cyl / GAS |
| Condition | Unknown |
2001 Cadillac Seville STS 4.6L
