Using Headlight as Short Finder
The headlight is used in place of the fuse. Enough current passes to power the circuit. When the short to ground is present, the headlight gets brighter as more voltage is dropped across the bulb.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Robert from Florida |
OPEN: Reliable Fuse brands that actually blow at designed amps |
TECH: Using Headlight as a Short Finder
TECH: POKY the test light Tech
TECH: Bad ground, a basic review
TECH: 4.2L F150 Blowing PCM Power Relay Fuse
TECH: igntion coil current
TECH: Engine won''t shut off with key
TECHTIP: No Crank No Start
