2000 Jeep Cherokee Classic, Engine/Propulsion Waveform
Capture of companion cylinders, one with good compression and one with bad compression. Cursors are evenly spaced and show that the peak occurs early on the cylinder with leakage.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Harvey from British Columbia |
| Engine | 4.0 L / 6 cyl / GAS |
| Component |
2000 Jeep Cherokee Classic 4.0L
| Component |
