2006 Volkswagen Jetta TDI, ECM/Inputs/Outputs waveform
Crankshaft was removed and the rear main seal with exiter ring for the crankshaft sensor was installed w/o vw special tool which indexes the exciter ring to the crankshaft. The exiter ring is part of the rear main seal and must be installed with the tool. Th...
| Engine | 1.9 L / 4 cyl / DIESEL |
| Component |
2006 Volkswagen Jetta TDI 1.9L
| Component |
