Comparing WASTE KV Vs. COMPRESSION STROKE
Excessive KV demand is determined by the ratio of Waste KV and Compression KV. If the ratio is greater than 1:5 it is questionable for further diagnosis of the firing time. Note also the noise factor of a wide spark gap.
Login to view this file Auto Repair Pros: Join iATN to view this file and others Vehicle Owners: Find a nearby iATN member to repair your vehicle Mac from Michigan |
