1997 Toyota Camry, ECM/Inputs/Outputs waveform
Pattern after the crank gear was replaced. The keyway slot in the old gear was worn and there was movement between the gear and the crankshaft. Possibly crank bolt was not tight enough for an extended time.
1997 Toyota Camry CE 2.2L
