1987 Nissan Pathfinder SE, ECM/Inputs/Outputs waveform
Signal generated from inner ring of VG30i optical distributor. Vehicle has hard code 11 causing PCM to go into limp mode. Optical module is somehow adding extra events unrelated to EMI.
| VIN | JN8HD16Y8H |
1987 Nissan Pathfinder SE 3.0L
| VIN | JN8HD16Y8H |
