2003 Ford Expedition, ECM/Inputs/Outputs Waveform
This screen capture is of the PATS circuits Tx (channel B at top) and Rx (channel A). At the time of the screen capture the engine would not crank and the Security light was flashing once per second. Code B1681 “Pats Transceiver Module Signal Not Received” wou...
2003 Ford Expedition Eddie Bauer 5.4L
