2005 Honda Civic EX, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 8/5/2013
Code is PO122 tps low volts. sweep looked good, but intermittently on closed throttle the voltage drops out. Resistence check on closed throttle also out of spec
Bill from California
2005 Honda Civic EX 1.7L
Engine1.7 L / 4 cyl / GAS
