2004 Chevrolet Impala LS, ABS/Inputs/Outputs Video
Posted to the Waveform Library on 10/24/2012
Common Mistake. The ABS Harness is checked with a DVOM set on Ohms or even checking by back probing with key on. Unless one pulls on the harness the broken wires inside the insulation will not show up.
James from Hawaii
2004 Chevrolet Impala LS 3.8L
Engine3.8 L / 6 cyl / GAS
SubsystemABS/Inputs/Outputs
